  3. extracting specific point in a MeasureAcrossSweep
  • Subscribers 136
  • Views 5045
Huf
Huf over 2 years ago
I do have a testbench where:
- a scaler value is getting measured
- many corners and uses cases are being swept through corners
- on top of that I sweep temperature across several points, this sweep is made in a local (or global) variable and is then "outside" the corner sweep
Now I want to measure the temperature coefficient of my scaler.
That is easy to do with a measure across sweep, if I only sweep 2 temperature points (I measure ymax and ymin of the scaler)
But now I'd like to automate things a bit more, and measure temco from -40 / 125 AND also tempo from 0 / 85 in the same testbebch
Is there a way, instead of calling for min or max value of the measure across sweep, to call for a specific entry of this list ?
I mean if my temperature points are -40, 0, 85 and 125. Can I specifically call for the 1st entry, the 2nd one, and so one ?
BR
