  3. Setting a routing only master instance transparent
  • Subscribers 129
  • Views 4644
JtiendraS
JtiendraS over 1 year ago
I have a routing only cell which is repeatedly used in multiple hierarchies. Is there anyway I can set the master instance transparent, which when instantiated in different levels take binding names present at instantiated level similar to a group copied.
Sync group works only at 1 hierarchy.
Jitendra S.
  • RobMan
    RobMan over 1 year ago
    Yes, you can use a transparent instance a routing cell. There are no additional binding requirements; transparent instance status negates this.
    Jitendra,
    If you have a routing only cell, this doesn't necessarily need to be a transparent instance. You could open the routing cellView, and do File→Properties and add two properties:
    Property Type Value
    extractToLevel int 1
    ignore boolean t
    This means that the extractor will ignore it as a separate instance, and also extract the contents so that the shapes within it would be seen as interconnect.
    Andrew Beckett over 1 year ago in reply to Andrew Beckett
    That said, Rob's suggestion to make it a transparent instance is probably the way I'd choose to do this.
