  3. One testbench for different analysis (S-parameters, ac,...
  • Subscribers 136
  • Views 5988
One testbench for different analysis (S-parameters, ac, transient)
engmsalik321
engmsalik321 over 2 years ago
How can I run different analyses (S-parameters, AC, transient) in a single test bench?
I tried connecting the sp1switch in series with the port, AC analysis, and transient work, but the S parameters were not correctly calculated.
I have tried making a variable to turn on and off the switch, but it does two simulations. Since I wanted to use the optimization, so I wanted the results to be calculated with the same parameters. Not changing parameters.
Also, I want the port to be disconnected for AC analysis and connected for s-parameter analysis.
Please let me know how it can be done.
Thank you.
    This works for me. What's not working? I assume you're setting the ac_position to 1 (and dc_position?). What do you need to actually change in the test bench? You can use port with ac and transient analysis too, after all.
