  3. Plotting Template in ADE Assembler and ADE Explorer
  • Subscribers 136
  • Views 5265
IceTea
IceTea over 2 years ago
My virtuoso verison is: sub-version  IC6.1.8-64b.500.27
I created two ADE Explorer cases and for each of them I saved a Plotting Template named differently such that no Plotting Template naming confusion exists between the two Explorer case, e.g. tb_bjt and tb_bjt_temp. Each explorer case run by itself refreshed the graphic results correctly. Then I tried to run both cases inside the  ADE Assembler. I could not find a way to get the two plotting windows as defined individually in the ADE Explorer. Can you help? Thank you,
