  3. Is spc file available in ADE Explorer/Assembler?
  • Subscribers 136
  • Views 1126
mtzikara
mtzikara over 2 years ago
I am using an internal simulator as a shell around spectre and the input I have to give at least in older versions of Virtuoso was a .spc file. This was done by loading the ADE-L state, it would find this file. Is this file available now with the maestro view? By loading the maestro view our simulator does not recognize any .spc file.
KR,
Maria
    Hi Maria,
    I'm not sure what you mean by "it would find this file"? Find this file where? If you have a custom simulator that runs in ADE (and it's a bit odd that it's a shell around spectre) do you have some custom simulator integration? I strongly suggest you contact customer support as otherwise there's a huge amount of guesswork as to what you are actually doing here...
