  3. Difference srrWave and drWave
  • Subscribers 136
  • Views 5841
tsnv
tsnv over 2 years ago
Going through the OCEAN Reference Manual the ocnPrint function mentions drWave as the waveform identifier. Checking the identifier of the results of my simulation, I get srrWave. What is the difference between the two?
    Andrew Beckett over 2 years ago +1
    You must be looking at an old OCEAN Reference Manual, as I only see references to srrWave. In a much older release, the waveform objects were drWave objects (this was just the print representation of the…
    You must be looking at an old OCEAN Reference Manual, as I only see references to srrWave. In a much older release, the waveform objects were drWave objects (this was just the print representation of the object). In essence though they are the same, it's just a newer interface was developed many years ago which changed from "dr" to "srr" (simulation results reader). Certainly in the IC6.1.8 and IC23.1 documentation it refers to srrWave everywhere.
