  3. Load Pull simulations without PortAdapter
  • Subscribers 137
  • Views 6702
Aravind Kappaganthula
Aravind Kappaganthula over 2 years ago
Hi
I would like to run load pull simulations with harmonic balance analysis. I do not have access to PortAdapter from rfExamples library. So I would like to run it using analoglib port with hb analyses.  I need to set sweep for magnitude and theta of reflection coefficient and run the simulation. How should I set up the simulation? Especially, at the output port. Can you help, please?
Many thanks.
  • tsnv
    tsnv over 2 years ago
    Searching for "Loadpull" in the Cadence Doc Assistant you will find a page showing an example with ports from analoglib.
