  3. LVS Mismatch
  • Subscribers 136
  • Views 6108
LVS Mismatch
Sazzad H
Sazzad H over 2 years ago
I added an LVS-cleaned design block at the top level with other blocks and components. At the top level, it is claiming again mismatched instances of the previously LVS cleaned block.
It's a 130nm SiGe BiCMOS process. Would you please give me some insights? Thanks
  • RobMan
    RobMan over 2 years ago
    Are there numerous parallel instances? It looks like some correspondence points (pin labels) in the layout might help.
    More detail required than this small excerpt required to full confirm/debug.
