  3. "Ignore Instances" not completely ignoring capacitor instance...
  • Subscribers 136
  • Views 2895
"Ignore Instances" not completely ignoring capacitor instance effects
MahdiMohammadi
MahdiMohammadi over 2 years ago
I'm simulating a CS-DAC, and was experimenting with the effect of an extra capacitor on the tail node.
To do that, I placed an ideal cap from analogLib on the node, and then measured in three cases:
  • No capacitor installed,
  • 100fF capacitor installed,
  • 100fF capacitor installed but ignored
Here are the results:
As you can see, there's almost no difference between ignoring or not ignoring the cap! I assumed the ignore instance option would cause it to act like the case without any capacitor.
I would appreciate your suggestions.
Best regards,
Mahdi
    Mahdi,
    That seems rather odd. Ignoring the capacitor this way should cause it to be omitted from the netlist - can you check if there is a capacitor in the netlist sent to the simulator?  Which simulator are you using?
  • MahdiMohammadi
    MahdiMohammadi over 2 years ago in reply to Andrew Beckett
    Dear Andrew,
    I just played with the cap and realized that even placing a 10fF mimcap has the same effect. So, I think the placement of this cap somehow changes the simulator's behaviour.
    And I confirm the cap is omitted from the netlist when ignored.
    I tried both Spectre and APS (with ++aps enabled).
    Best regards,
    Mahdi
  • MahdiMohammadi
    MahdiMohammadi over 2 years ago in reply to MahdiMohammadi
    I realized what was going on.
    I was using bus instantiation (I don't know if that's the correct term) for the tail and input transistors. So without the capacitor, there are 15 different tail nodes. However, when I place the capacitor, regardless of whether it is ignored, since the cap is instantiated only once, all the tail nodes are shorted together, causing the circuit to behave completely differently.
    I'm sorry about the mistake.
    Andrew Beckett over 2 years ago in reply to MahdiMohammadi
    Ah yes - sorry, I should have spotted that in the schematic! Selecting the node above the capacitor would have made that obvious...
