  3. ocnPrint to File
  • Subscribers 136
  • Views 6551
ocnPrint to File
tsnv
tsnv over 2 years ago
Using `ocnPrint` to write a waveform to a file, I am unable to locate the file it writes to if it even writes to the file. I have tried relative and absolute paths and searched through the simulation results directory, `getSkillPath()`directories, as well as the project location. Oddly enough the output that should be printed to the file is printed in the CIW. The OCEAN commands are called through Python-Skill Bridge, which simply allows to use OCEAN commands in Python for further processing.
How can I use the `ocnPrint`-function to write the waveform to a findable file?
# copied from File > Create Script... in maestro
ws['ocnSetXLMode']("explorer") # set mode to OCEANXL
ws['ocnxlProjectDir']("~/simulations") # location of simulation results
ws['ocnxlTargetCellView']("Library", "cell", "view") # substituted values by general names
ws['ocnxlResultsLocation']("") # same as project dir
ws['ocnxlSimResultsLocation']("") # same as project dir
ws['ocnxlMaxJobFail'](20)
# own addition
ws['openResults'](path_data)
ws['selectResult'](Symbol("tran"))
data = ws['getData']("/net1")
res = ws['ocnPrint']("?output", "./myOutputFile", data) # copied from OCEAN reference guide
    Given that this "Python-Skill Bridge" is not a Cadence feature, perhaps you should ask the authors of it? I'm unfamiliar with it (you could provide a link for anyone else who has time to explore it, although adding the URL will put the post into moderation as potential spam - if you do that and then appeal it, I'll allow the post).
    The arguments for ocnPrint look reasonable, assuming this bridge interface passes them through correctly.
  • tsnv
    tsnv over 2 years ago in reply to Andrew Beckett
    My apologies for the premature forum post. The script does work when implemented in a normal SKILL script; should have started with this. The issue was with how the path is passed in the function call. It should have been: ws['ocnPrint'](data, output='~/myOutputFile")
    Link to the Python library for those interested: Python-Skill Bridge
