  3. How to use device models with spectre circuit simulator
  • Subscribers 136
  • Views 6837
jkwak582
jkwak582 over 2 years ago
I'm trying to use HiSIM2 with ADE-L.
I read "Spectre Circuit Simulator Components and Device Models Reference". I believe the model is supported by cadence.
However, I got the error below when I ran ADE-L simulation.
Error found by spectre during hierarchy flattening.
ERROR (CMI-2119): I17: Cannot instantiate the hisim2 type instance using a primitive. Instantiate the instance using a model and rerun the simulation.
How do I use the models supported by cadence?
Below is my netlist
// Generated for: spectre
// Generated on: Apr 29 10:06:50 2024
// Design library name: TCAS_IVR
// Design cell name: hvsim
simulator lang=spectre
global 0
parameters vds=1 vgs=1
// Library name: TCAS_IVR
// Cell name: hvsim
// View name: schematic
V7 (net1 0) vsource dc=vgs type=dc
V6 (net2 0) vsource dc=vds type=dc
I17 (net2 net1 0 0) hisim2 w=10u l=10u
iabstol=1e-12 temp=27 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 \
sensfile="../psf/sens.output" checklimitdest=psf
tran tran stop=1u errpreset=moderate write="spectre.ic" \
writefinal="spectre.fc" annotate=status maxiters=5
save I17:d
    As the error suggests, you can't instantiate devices like this without a model. Models are necessary to provide the appropriate set of parameters to tune the model equations for the general hisim2 device - see "spectre -h hisim2" to see the available model parameters.
    Very simplistically, I could create a model file and include it in the Setup→Model Libraries in ADE, where the content is:
    model nch hisim2 type=n
    (that's pretty much the bare minimum, defining whether the transistor model is NMOS or PMOS; every other parameter would be at the default). Then set the model parameter on I17 to be "nch" to netlist it as nch rather than hisim2 - you'd then see:
    I17 (net2 net1 0 0) nch w=10u l=10u
    Of course, you need appropriate parameters for your technology - the default model parameters with hisim2 are never going to be appropriate for a real life technology. Has somebody provided you with a fitted model for your technology?
