  3. Extract x and y Vector from srrWave
  • Subscribers 129
  • Views 5765
tsnv
tsnv over 1 year ago
The goal is to extract the x and y vectors from an srrWave. In a first step from a single design point, but in a later stage ideally from a parameter sweep simulation. The current approach to get the x and y vectors from a waveform from a node voltage of a transient simulation is shown below. The code is written in Python. Python-Skill Bridge is used to forward the OCEAN commands. The function extracting the x and y vectors:
def wave2vec(ws, waveform):
x_vec = ws.dr.get_waveform_x_vec(waveform)
x = []
print(f'Vector length: {ws.dr.vector_length(x_vec)}')
for i in range(ws.dr.vector_length(x_vec)):
x.append(ws.dr.get_elem(x_vec, i))
y_vec = ws.dr.get_waveform_y_vec(waveform)
y = []
print(f'Vector length: {ws.dr.vector_length(y_vec)}')
for i in range(ws.dr.vector_length(y_vec)):
y.append(ws.dr.get_elem(y_vec, i))
return x, y
Getting the waveform data from the simulation results and calling wave2vec:
# setup Maestro mode explorer
ws['ocnSetXLMode']("explorer") # set mode to OCEANXL
ws['ocnxlProjectDir']("~/simulations") # location of simulation results
ws['ocnxlTargetCellView']("library", "cell", "view")
ws['ocnxlResultsLocation']("") # same as project dir
ws['ocnxlSimResultsLocation']("") # same as project dir
ws['ocnxlMaxJobFail'](20)
ws['openResults'](path_data)
results = ws['results']()
ws['selectResult'](Symbol("tran"))
data = ws['getData']("/net1")
x, y = wave2vec(ws, data)
The data variable does hold the correct result, i.e. the node votlages in an srrWave object (from a similar post), and the code runs without errors. However, the return values from `wave2vec` are not as expected: x returns [1.0] and y returns [<remote object0x...>].
How can I change the method above to correctly access the x and y vectors of an srrWave in case of a single design point and, if possible, in case of a parameter sweep simulation?
    Without details of what this Python-Skill Bridge does or where it comes from, I think it will be hard for anyone to answer this (it's not a Cadence-provided capability). Do the maintainers of that have a forum or issues list?
  • tsnv
    tsnv over 1 year ago in reply to Andrew Beckett
    I should have sent the SKILL code instead, my apologies. In SKILL I get the same results.
    Main code:
    ocnSetXLMode( "explorer" )
    ocnxlProjectDir( "~/simulations" )
    ocnxlTargetCellView( "library" "cell" "view" )
    openResults( "/somepath/Ocean.0/psf/tran/psf/" )
    selectResult( 'tran )
    data = getData( "/net1" )
    ocnPrint( data )
    ocnPrint( abWaveToList( data ) )
    ocnxlEndXLMode( "explorer" )
    abWaveToList.il (similar to wave2vec function):
    /* abWaveToList.il
    Author     A.D.Beckett
    Group      Custom IC (UK), Cadence Design Systems Ltd.
    Language   SKILL
    Date       Nov 17, 2003
    Modified
    By
    Convert a waveform to a list
    SCCS Info: @(#) abWaveToList.il 11/17/03.15:08:15 1.1
    *                  (abWaveToList wave @key transpose)                   *
    *    Take a waveform object, and return it as a list of xy pairs. Or    *
    * if transpose is set, it returns a list of x values followed by a list *
    *                             of y values.                              *
    (procedure (abWaveToList wave @key transpose)
      (let (xList yList xyList len
        (xVec (drGetWaveformXVec wave))
        (yVec (drGetWaveformYVec wave))
           (setq len (drVectorLength xVec))
           ; Return value of this if is the list
           (if transpose
           (progn
            (for i 0 (sub1 len)
             (setq xList (tconc xList (drGetElem xVec i)))
             (setq yList (tconc yList (drGetElem yVec i)))
            (list (car xList) (car yList))
           ; else
           (progn
            (for i 0 (sub1 len)
             (setq xyList (tconc xyList (list (drGetElem xVec i)
                              (drGetElem yVec i))))
            (car xyList)
           ) ; if
           ) ; let
      ) ; procedure
    Andrew Beckett over 1 year ago in reply to tsnv
    I think (without testing this) the problem is most likely because your openResults is opening the root of the results - so if you have corners, sweeps etc, there will be multiple simulation runs and hence you've got a famlly of data (with the sweep variables). This happens even if there aren't any sweeps - and so the abWaveToList won't work properly because it's not expecting waveform data. Your edited post above makes that less obvious because it just says openResults(data path) whereas before it was:
    If that was a single point result:
    openResults( "/somepath/Ocean.0/1/tran/psf/" )
    then I think it should work. You either need to iterate over the point directories, or make your vector processing able to handle family data.
  • tsnv
    Indeed, I assumed "*/Ocean.0/psf/tran/psf" was the correct path. Running the Python code with the "*/Ocean.0/1/tran/psf/" solves the issue. I will edit the post back to show the path.
    Thank you for the help!
