  3. Virtuoso - align instances to match pin order
  • Subscribers 136
  • Views 803
Paul Lynch
Paul Lynch over 2 years ago
I would like to align levelshifts to match pinout order from a hard IP block.
There are various levelshifter types being used so they need to be in the correct order.
In the past I have used the digital placer for this task reasonable successfully.
  1. Is there a function in IC studio to perform this task?
  2. Is there a function to select or deselect every Nth instance/via selected?
    1. Sometimes need to rotate or flip ever 2nd or 3rd selected device.
  3. Is there a function to drop contacts onto a MOS device gate automatically?
    1. Sometimes this is built into pcells or we have custom SKILL. I need to understand whether to continue supporting existing SKILL functions or IC23 can replace them.
Thanks in advance,
Paul.
