  3. How to setup ADE Explorer to save last N runs automatic...
  • Subscribers 136
  • Views 7317
How to setup ADE Explorer to save last N runs automatically
nrk1
nrk1 over 2 years ago
How to setup ADE Explorer to save last N runs automatically? With ADE-L the following line in .cdsinit would save the last 5 runs.
envSetVal("asimenv.misc" "numberOfSavedRuns" 'int 5)
Nagendra
    Nagendra,
    There's not a direct equivalence. The closest is:
    envSetVal("maestro.explorer" "onHistoryNameCollision" 'cyclic   "IncrementAsNew")
    which increments the Explorer history number after each run, so it's equivalent to saving after each run. It doesn't limit the number of saved "histories" to N runs - you have to manage that yourself (this was not a particularly widely used ADE L feature). ADE Assembler has the ability to save full histories after each run and limit those to N runs (on the Options→Save form).
  • nrk1
    nrk1 over 2 years ago in reply to Andrew Beckett
    Thanks! Both work. I find this feature useful in the exploratory phase when making changes to (small) circuits and simulating them. Too lazy to explicitly save every result.
    The assembler option is easier. Is there a reason to not use assembler for everything?
    Nagendra
    Andrew Beckett over 2 years ago in reply to nrk1
    Not really. The only point is maybe that there are more mouse clicks needed in Assembler because of the fact that you can have multiple tests, so you then need to indicate which test you are operating on.
