  3. Virtuoso version update issue
  • Subscribers 136
  • Views 6782
baobov587
baobov587 over 2 years ago
Which sub version of 6.1.8 does the following function start from? When simulating STB, virtuoso will automatically add ". IPRB-DM" to the netlist.
For example, analysis ('stb? Start "1"? Stop "1000M"? Probe "I0. IPRB-DM"? UsingProbeMode t)
What I have learned is that IC6.1.8-64b.83 does not have this feature yet, while IC6.1.8-64b.500.30 already has this feature.
    Support for differential (and common-mode) stability analysis using diffstbprobe is available in all sub-versions of IC6.1.8. The interface in ADE changed in a hotfix (I forget which one) but in the early versions ADE looked like this:
    (see the "Mode Type" at the bottom when I've selected a diffstbprobe). The netlist looks like this:
    stb stb start=1 stop=10G probe=I25.IPRB_DM annotate=status
    The OCEAN equivalent of the ADE setup is:
    analysis('stb ?start "1" ?stop "10G" ?probe "/I25" ?usingProbeMode t )
    If you'd wanted common-mode stability, it would be this:
    analysis('stb ?start "1" ?stop "10G" ?probe "/I25" ?usingProbeMode t ?stbProbeMode "common" )
    In later IC6.1.8 versions the UI changes, but the OCEAN is the same:
  • baobov587
    Thank you Andrew!
    Your suggestion is very detailed and practical.
