  3. Use variation for sweep different files in AMS simulati...
  • Subscribers 129
  • Views 4029
Use variation for sweep different files in AMS simulation
nonameirvine
nonameirvine over 1 year ago
I would like to include 2 different files in the same path in ams simulation, so I define a variation naming nfile with two value nfile1 and nfile2, then in my ams including options I set ../path/VAR("nfile")
but it cannot do netlist. could you advise a way to sweep it?
    What kind of file are you trying to include and from which UI? You can do this with Spectre files by adding (in the model library form) if you just put VAR("nfile") (without the path part) and add the path into Setup->Simulation Files->Include Path. The variable can then be set to "file1.scs" (with the quotation marks) and it will work.
    You cannot do this in AMS with either Verilog files (on Simulator->Options->AMS...) or with stimulus or definition files on Setup->Simulation Files.
