  3. Maestro - device parameter as variable
  • Subscribers 136
  • Views 3462
firebolt3
firebolt3 over 2 years ago
How to pass design variable (from Maestro setup) to transistor paramaters like width, length, fingers, or multipliers? This helps to fine tune my design across corners. I remember something like par.
virtuoso version ICADVM20.1-64b.500.34
    Andrew Beckett over 2 years ago +1
    You either put the design variable name in that field on the properties for that instance (some PDKs don't allow variables in such parameters though), or you use the "Parameters" section (via the Variables…
    You either put the design variable name in that field on the properties for that instance (some PDKs don't allow variables in such parameters though), or you use the "Parameters" section (via the Variables and Parameters assistant) in ADE Explorer/Assembler to allow you to add overrides or sweeps of component values.
