  3. automating schematic to post layout simulation flow
  • Replies 12
  • Subscribers 131
  • Views 8392
supriyo1985
supriyo1985 over 1 year ago
I need some help automating a flow that takes a schematic as input, calls the automatic placer and router in Layout Suite GXL, extracts parasitics using Calibre PEX, and then runs a post-layout simulation.
I was planning to use Ocean Script for this purpose. I noticed that when I executed the above steps manually through GUI, all the commands and outputs were printed on the Virtuoso main window. For example, the automatic router invoked the following commands and several others.
*    Begin Min-Spanning-Tree Routing Flow for Normal Nets    *
REPORTING_STATS | Elapsed Time: 0.0 Secs | Mem: "Current: 2369.00" Mb | Cmd: initialize_partition -set sel:4654ce30
[::ia:: INFO] Sourcing /usr/local/packages/cadence_2021/IC618/share/cdssetup/dfII/ia/tcl/checkRoutability/flow.tcl
*    Begin Check Routability Flow                            *
route_optimize -set sel:4fda8f80 -route_over_pins true -truncate_at_pins false -allow_wrongway true -make_only_net_spec_vias true -uniform_taper_to_first_via true
However, when I manually executed the above command, the tool failed to recognize it.
*Error* eval: undefined function - route_optimize.
How do I go about this problem? Could anybody help? I have attached a figure so that it is easy to understand what I am doing.
Regards
Supriyo
  • supriyo1985
    Basically, I want to know how to call the auto placer and auto router from the command line.
  • RobMan
    RobMan over 1 year ago in reply to supriyo1985
    Please see...
    Virtuoso Layout Suite SKILL Reference (cadence.com)
    Specifically Virtuoso Layout Suite SKILL Reference -- vcpfeRunCustomDigitalPlacer (cadence.com)
    ... and associated functions.
    Virtuoso Layout Suite SKILL Reference -- Space-based Router Functions (cadence.com)
  • supriyo1985
    supriyo1985 over 1 year ago in reply to RobMan
    Thank you. So far, I have successfully executed the following 3 steps using the SKILL code.
    1. Generate from schematic
    2. modgen creation (my old post helped a lot, https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/38265/skill-command-for-layout-execution)
    3. automatic placement
    for routing, I am calling the following function
    rteOptimizeRoute(
    ?cv (geGetEditCellView)
    ?critic t
    ;?checkAntenna t
    ;?detailCritic t
    ;?excludeNet ""
    ;?excludePowerGround ""
    ?reduceVias t
    ;?region ""
    ;?set t
    ;?useDoubleCutVias t
    But it does not seem to be routing anything.
    INFO: Router used all 32 hierarchy levels for loading the layout data.
    === interpreted: -check_rule { minarea minedge minenclosedarea minwidth samenet samenet_crossing }
    Begin droute...
    Begin clean...
    ### attempted 0; success 0; guides 0;
    End clean 0.0s (kernel), 0.0s (user), 0.0s (elapsed), 2294.0MB vm, 2294.0MB peak vm
    Begin critic...
    End critic 0.0s (kernel), 0.0s (user), 0.0s (elapsed), 2294.0MB vm, 2294.0MB peak vm
    End droute 0.0s (kernel), 0.0s (user), 0.0s (elapsed), 2294.0MB vm, 2294.0MB peak vm
    Begin critic...
    0 routes were changed.
    Am I missing something?
  • supriyo1985
    Thanks. Is this the function to use for routing the nets?
    rteOptimizeRoute()
    It does not seem to be routing anything.
  • supriyo1985
    supriyo1985 over 1 year ago in reply to supriyo1985
    After the routing, I also need to create labels for the pins; otherwise there is LVS mismatch. Could you also share how to automate the label creation process?
  • supriyo1985
    I have had some success in automating the flow, but I need help to move further. Here are the details of what I have done so far and what is missing. I am sharing this through a Google Drive link as I have been unable to post the content here.
    https://docs.google.com/document/d/1qRC95SYJFRmwyvdZ9grFzQ8W-OvS8G0U/edit?usp=share_link&ouid=101268368332665463426&rtpof=true&sd=true
    I am also trying to reach Cadence online support through a university representative.
    Any help is highly appreciated.
    Regards
    Supriyo
  • AB_1718115862799
    AB_1718115862799 over 1 year ago in reply to supriyo1985
    If you get the cellview data object for the layout, you can iterate through the terminals, pins, and figures to add a label at the center box of terminal pin figure.
  • AB_1718115862799
    Routing is tough. I see you're using IC6.1.8. There's a number of ways to route, I'll mention a couple here:
    1. you can use the Wire Assistant to create a routing preset. Then call the preset like this:
       vsrLoadPreset("myPresetName")
       _iaAutomaticExecuteCmd('autoRoute 'all nil)
    You can also do 'selected instead of 'all.
    2. The more complex way, find the Cadence Space Based User Guide, and the Command Reference. You'll write a routing script in TCL syntax and call it in SKILL with:
    rdeSource("/path/to/my/tcl.script" t t)
    Unfortuantely, you really need to understand the concepts of constraints, constraint groups, and constraint precedence to even become functional with this approach. It's very powerful but very tough to use and harder to debug.
  • supriyo1985
    supriyo1985 over 1 year ago in reply to AB_1718115862799
    Thanks a lot. I am trying solution 1 now, which gives better results than lxSelectedRoute. However, I still have to keep the GXL editor open for Solution 1 to work. Otherwise, I get the following error, although the preset file exists in the dir.
    *Error* (IA-30123): Unable to load preset file autoDeviceRouting.preset from directory /home/local/eda11/sm84275/workspace/****/.cadence/dfII/ia/presets.
                        This is because directory /home/local/eda11/sm84275/workspace/****/.cadence/dfII/ia/presets does not exist.
                        Ensure that the specified directory is exist.
  • supriyo1985
    There seems to be some issue with the nclAnalogAutoPlaceCB(layout_view 3) function. If I call this (load "") after step 1 from within the same file, placement looks different (right figure) than if I execute it directly from CIW (left figure). The left figure result looks correct to me as all components are contained within the PR boundary. It seems that modgen creation in step 1 is affecting nclAnalogAutoPlaceCB’s behavior.
    Please help.
