  3. [Continue thread] Change Virtuoso Studio ADE Windows Title...
  • Replies 7
  • Subscribers 136
  • Views 8076
[Continue thread] Change Virtuoso Studio ADE Windows Title Style
SimbaG
SimbaG over 2 years ago
This continues on:
[Thread 1] https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/56852/https-community-cadence-com-cadence_technology_forums-f-custom-ic-design-38053-display-current-view-in-window-title-bar
Andrew suggested a solution which is:
[Solution 1] https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nSbFEAU&pageName=ArticleContent
Issue: ADE will change the title back to default format while clicking the save button
Steps to reproduce:
1. Copy the code from the Solution 1 Page. Load the CCSchangeWinName.il.
2. Open an ADE Explorer window. Verify if the window title is changed as we expected.
3. Menu -> Output -> Add -> Expression, and type anything on the expression.
4. Click save, the ADE title now becomes the default style.
I think there is a trigger missing, the trigger should be aimed at saving or at any events that will change the ADE title.
Thanks.
    Andrew Beckett over 2 years ago in reply to SimbaG +1
    virtuoso -V give you the major version, whereas virtuoso -W shows the minor subversion. This is due to a new feature (that's there in IC6.1.8 too, but turned off by default) to update the banner with…
    Which IC sub-version are you using? I'm doing this in IC6.1.8 ISR35, and it seems to work OK for me...
  • SimbaG
    SimbaG over 2 years ago in reply to Andrew Beckett
    $ virtuoso -V
    @(#)$CDS: virtuoso version IC23.1-64b 06/21/2023 09:33 (cpgbld16) $
    It seems like it only happens on Virtuoso Studio (23+)
  • SimbaG
    SimbaG over 2 years ago in reply to SimbaG
    On the About page, it is IC23.1-64b.43
    I do not know why the subversion 43 is not included on the virtuoso -V command.
    This is due to a new feature (that's there in IC6.1.8 too, but turned off by default) to update the banner with a * to indicate that the ADE setup has changed. It's on by default in IC23.1
    The right way is to get the windowNameFormat/iconNameFormat supported for ADE windows (it doesn't look as if there's a CCR for that; I suggest you contact customer support to request this).
    As a workaround you could turn off the updating of the banner to reflect the changed status:
    envSetVal("maestro.gui" "updateTitleToReflectUnsavedChanges" 'boolean nil)
  • SimbaG
    Thank you very much for the workaround.
    Is there a trigger for the "updateTitleToReflectUnsavedChanges" event?
    This is not an event. It's a cdsenv variable that is checked as part of a function that is called whenever ADE has changed something and determines whether the title should be updated. There's no public trigger that is being used for this, so no, there's no trigger. Which is why I suggested it as a workaround...
    As I said, the right solution is to get ADE to honour the same windowNameFormat/iconNameFormat env vars that are used in other applications in Virtuoso. Then there would be no need to mess around with triggers to solve this problem.
  • SimbaG
    I see, thank you Andrew.
