  3. Pegasus DRC Run fails
  • Subscribers 129
  • Views 5322
Saumeek
Saumeek over 1 year ago
While running DRC using Pegasus in Cadence Virtuoso:
"ERROR (XSTRM-321): Translation cannot be continued as the '-enableColoring' option is used, but the layer map file is not found. This is because either the -layerMap option is not specified or technology does not have the layer map file. Use a valid layer map file and then translate again.
INFO (XSTRM-273): Translation failed. '1' error(s) and '0' warning(s) found.
ERROR: Problem happened while processing strmout."
There are layer map files,
how and where to specify them in cadence virtuoso gui. Please guide.
  • Saumeek
  • RobMan
    RobMan over 1 year ago in reply to Saumeek
    These are essentially options relating to stream out. Layer mapping and the enable coloring are available on the Pegasus 'Input' tab.
