  3. Circular arrays in layout L
  • Subscribers 136
  • Views 5737
rb1993
rb1993 over 2 years ago
Hello all,
I am new to cadence platform. I have an entity (linear array of rectangles) that I want to replicate in a circular form (say 10 degrees apart). create an array that follows a circular path around origin. What is a quick and easy way to do this?
    You'd need a short piece of SKILL code to do this easily (you could do it manually, but placing 36 instances would be a bit tricky). The first thing to be aware of is that instances can only be placed at 90 degree multiples (and a flip), but this can be worked around by using dbCreateXformPCell. Here's an example I quickly did. Firstly I created a layout called "metarray" with the structures I wanted to have arrayed:
    Then I created a "layout_xform" view - the benefit is that when you instantiate this, you can specify a "mag" (magnification) and "angle" - it generates a PCell that flattens the contents and then changes the scale and orientation by an arbitrary angle (in degrees). I called this with the above layout open:
    dbCreateXformPCell(geGetEditCellView() "mylib")
    Then I used this SKILL code:
    defMathConstants('CCFgenCircle)
    procedure(CCFgenCircle(@key (cv geGetEditCellView()) (radius 20.0)
        (step 10.0) lib cell
        (view "layout_xform") (origin 0:0))
      let((master x y (angle 0.0) rads)
        master=dbOpenCellViewByType(lib cell view)
        while(angle<360
          rads=angle/180.0*CCFgenCircle.PI
          x=cos(rads)*radius+xCoord(origin)
          y=sin(rads)*radius+yCoord(origin)
          dbCreateParamInst(cv master "" x:y "R0" 1
            list(list("angle" "float" angle)))
          angle+=step
    With a new layout open (mylib/circarray/layout) I then ran in the CIW (with the circarray window the current window):
    CCFgenCircle(?lib "mylib" ?cell "metarray")
    This uses the default origin (0:0), radius (20) and step (10), but you could call CCFgenCircle(?lib "play45" ?cell "metarray" ?radius 30.0 ?step 20) if you wanted something different.
    The result of the above is:
