  3. How to set up ADL explorer to run a comparator
  • Subscribers 136
  • Views 4964
elshazlio
elshazlio over 2 years ago
I am learning how to use Virtuoso on my own, so I designed this comparator (with hysteresis) circuit using MOSFETs and put it in this symbol, then I created a test bench for it.
But I don't know what to put in ADL Explorer to test and run it! I guess I have to add the Vin in the design variables, but what else should I add? Also what pins should put in the Analyze section? Anything else I should take note of? Thank you in advance.
