  3. PAE in wireless analysis with multiple DC sources
  • Subscribers 137
  • Views 5037
bernardoleite
bernardoleite over 2 years ago
I am running an envelope-wireless analysis and I would like to obtain the power-added efficiency with two or more DC sources.
Here is a simple test I carried out. When I fill the field DC Bias sources in the output wprobe (WPRB0) with  V0 V1 or V0,V1, I get the same WPRB0.Pdc as for when only using V0 (alternatively, using V1 V0, the result is the same as for only using V1).
The plural on DC Bias sources led me to believe it would be possible to calculate the PAE for two sources, but iit is solely considering the firts mentioned source. Does anyone know how to correctly set it up?
Thank you.
IC23.1-64b.ISR6.30
Spectre 23.1.0.442.isr7
