  3. Spectre simulation terminated after S-parameter fitting...
  • Subscribers 137
  • Views 5740
Seungwoo Kang
Seungwoo Kang over 2 years ago
Hello Sir,
I design LC oscillator, so using S-parameter of inductor I simulated PSS, PNOISE simulation.
But, below phrase appeared in the log file and the simulation stopped.
Notice from spectre during initial setup.
In file `***/EMX/EMX_work/ka_EMX_Saffron24_lane_dco_ind_73pH_q32p4.work/Saffron24_lane_dco_ind_73pH_q32p4.s4p', the maximum passivity violation is 0.000004% at 5 MHz.
Perform S-parameter fitting for datafile: ***_dco_ind_73pH_q32p4.s4p
MMSIM Version is 20.1isr12. Is there any solution?
    Andrew Beckett over 2 years ago in reply to RohitRohan +1
    I also wouldn't expect the simulation to stop with these messages. I suggest you look at Tawna's app note: 7 Habits of Highly Successful S-Parameters, Spectre 21.1 Andrew
  • RohitRohan
    RohitRohan over 2 years ago
    Hai Seungwoo,
    Check the S Parameter data, if they are correct data.
    Also check the file format of the S Parameter Data.
    Check if the data covers the required frequency.
    Rohit Rohan
