  3. calcVal with sp confusion
  • Subscribers 136
  • Views 6063
Brad RFeng
Brad RFeng over 2 years ago
calcVal() confusion -
For a simple sp analysis with no local sweeps, no global or local parameters, calcVal() won't retrieve a previous history. It seems calcVal() will retrieve the active (last) history but that's not very useful.
Notice in the Results table myWave0, myWave0b, myWave_history0 fail to evaluate. All three errors mention arg #1 should be an integer but all expressions have the same arg #1 including the expressions that work.
  • JankoK
    JankoK over 2 years ago
    Hi Brad,
    Strange... this should work. I was running some very complex examples last week and those were all successfully reading from history items. I guess I need to try SP analysis specifically?
    Which Virtuoso version are you using?
    BR
    /Janko
  • Brad RFeng
    Brad RFeng over 2 years ago in reply to JankoK
    Hi Jankok,
    Yes, I think the problem is related to using the sp analysis with calcval. Perhaps I don't have the correct arguments? I'm using version IC61.8 330
    Brad
  • JankoK
    JankoK over 2 years ago in reply to Brad RFeng
    Hi Brad,
    Yup, it errors out in your version and in the latest 6.18 (ISR35), but it seems to work in the latest IC23.1 (ISR7).
    Please upgrade if you can, try it out and let me know.
    BR
    /Janko
