  3. The env variable to set schematic find zoom
  • Subscribers 136
  • Views 5701
sjwprcker
sjwprcker over 2 years ago
I would like to set the default find zoom option checked in schematic find. I have set
envSetVal("schematic" "findZoomButton" 'boolean 't)
However, it doesn't work as expected.
I am wondering if anyone knows the correct solution?
BR
    This doesn't work - there's a long-standing CCR for this, CCR 436004. The UI updates the env var, but does not use the env var to initialise the form.
  • sjwprcker
    sjwprcker over 2 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for your feedback. That's it.
    Andrew Beckett over 2 years ago in reply to sjwprcker
    FYI - I asked R&D to fix this (as it was simple) and they've now done so - this will be available in IC23.1 ISR9 (together with support for another environment variable, findAndReplaceZoomScale to adjust the scale). I just tested this, and it works well.
