  3. How to decrease the capacitance of charging and discharging...
  • Subscribers 136
  • Views 5293
How to decrease the capacitance of charging and discharging at the MSB of current steering DAC
Phd SA88
Phd SA88 over 2 years ago
Dear Sir
I'm designin a 3 bit binary differential current steering DAC using transmission gate as a switch in the top and the bottom of my circuit. When the transition at MSB is occured, the time of charging and discharging the capacitance is increased which make the transition more slow, as can be seen in figure below: when the binary switch from '001' to '110', the rised slope and decreased slope are not identical. It is necessary that the descent slope and the rise slope should be equal. This provide an asymmetry of the curve and i can’t reconstrut my input signal which is a sinusoidal signal. Moreover, each transition where all the bits change, the rised slope and the decreased slope i are not equal.
Also, i try to switch from "010" to "011", i have the same results. during the descent or rise of the signal, there is a change in the slope, the variation is more slower; as presented in this figure : the best case dy1 and dy2 should be equal because thay have the absolute value of slope and this is not the case. How can i decrease the capacitance of charging and discharging at the MSB of current steering DAC nad make the transition at MSB more faster. I'm so gratefull if you can help me
  • Phd SA88
    Hi
    I'm designin a 3 bit binary differential current steering DAC using transmission gate as a switch in the top and the bottom of my circuit. When the transition at MSB is occured, the time of charging and discharging the capacitance is increased which make the transition more slow. In order to reduce Ron and the lower thecapacitance of charging and discharing i need to use bootstrapped Transmission gate in cmos technology; I ask if you can help me to show thye architecture of this Bootstrapped Transmission Gate circuit design.
    Andrew Beckett over 2 years ago in reply to Phd SA88
    Please do not post the same question in multiple forums (please read the Guidelines for the Custom IC Design Forum). I've joined your two posts.
