  3. Modifying Model Groups based on Environmental Variable
  • Subscribers 136
  • Views 5276
jdsherman
jdsherman over 2 years ago
We have a setup where we would like to change the Section of a Model in the Corners Setup based on an environment variable loaded during initialization. IE, the PDK comes with some environment variable VAR that is defined in a .cdsinit, and one of the corners we have defined requires a section to be defined as that environment variable. We're currently resorting to having a user load in an SDB with the appropriate model section modified in a hardcoded fashion. Our current idea is to write a SKILL script to copy over a template SDB file with a placeholder for the section, then copy it over during initialization and replace the section with the environmental variable, or having multiple SDB files (one for each variable) and loading in the appropriate one on startup.. This didn't seem like an elegant solution, so I'm hoping someone has a better idea here!
Thanks!
    The fundamental problem is that Spectre itself doesn't allow the section to be specified as a UNIX environment variable - if it did, this would make your life easier. Because of that, I would be concerned that anything you do to try to enable this is going to be messy and fragile (likely to break), so I would avoid trying to do this altogether.
    Environment variables are allowed in the path to the model file though, so you could always achieve this by having a set of simple wrapper model files (I think this is cleaner/simpler than your switching SDB files):
    // file mymodels_tt.scs
    include "realModels.scs" section=tt
    // file mymodels_ff.scs
    include "realModels.scs" section=ff
    etc, and then specifying the model file in ADE as mymodels_$MODELSECTION.scs
    Other than that, I would contact customer support and request spectre be enhanced to support UNIX env vars in the section name.
