  3. Need help in extracting a SPICE from a layout
  • Subscribers 136
  • Views 5769
gaddan14
gaddan14 over 2 years ago
Hello
I have a layout generated in Virtuoso for a simple ALU circuit. The layout was generated from a verilog code compiled by design_vision, with a floor plan and P&R created in INNVOUS and then imported in Virtuoso.
The design passed the DRC in Virtuoso in generic PDK 45.
Now I want to do the parasitic extraction for the layout and generate a SPICE netlist for the extracted version.
The problem I am currently facing is, since I only have a layout view of the ALU and not the schematic, I am unable to run the LVS test and subsequently do the parasitic extraction for netlist generation.
I used to extract parasitics and do the LVS for simple cells. This situation is new to me.
I thereby wanted to know if there are any procedure where I can directly extract a SPICE netlist from the layoutt?
Your help and guidance in this matter, as to what tools and processes I need to use, will be greatly appreciated.
  • RobMan
    RobMan over 2 years ago
    You can use a Verilog top level netlist for PVS/Pegasus LVS.
    I assume it's a small digital design if intending to target a spice netlist. What simulator are you intending to use?
    Consider dspf or new i-dspf flow instead of spice.
