  3. Saving Currents With ':' Delimiter
  • Views 2580
sgcad
sgcad over 2 years ago
Hi
When I use a Spectre save statement NM0:d to save the drain current, the resulting output signal appears as both NM0:1 and NM0/D as shown below.
As far as I understand, this happens independently from save options such as sub-circuit probe level.
I'd prefer to get the output NM0:d instead, and only that. In another environment, although with a different PDK, I'm getting the desired result but can't find the option that is set. I've already consulted the following resources:
  • Spectre Tech Tips: Spectre APS Save Overview - Part 1
  • Spectre Tech Tips: Spectre APS Save Overview - Part 2
  • Using Spectre SAVE Effectively (RAK)
but so far no luck. Can you point me in the right direction? Thanks very much for your response.
    A quick answer (not sure I'll have time to check/experiment). ViVA does show the mapped names for outputs, so the /D might actually be the :d output, mapped to schematic names.
    You can check by using the OCEAN functions:
    openResults("/path/to/psf")
    selectResult('tran) ; or whatever the analysis
    outputs(?map nil)
    This will show the unmapped names. Without ?map nil it will give the mapped names.
  • sgcad
    sgcad over 2 years ago in reply to Andrew Beckett
    Thank you very much for your response. It took me a while to get back to this topic as a tapeout was asking for priority.
    I've now checked with the OCEAN functions you listed, and indeed the names using the / delimiter are mapped.
    Is there a way to set-up ViVa such that it only shows the unmapped names? A solution using the .cdsinit file would be preferred.
    Thanks!
    Andrew Beckett over 2 years ago in reply to sgcad
    No, this is not possible as far as I know (without hacking information in the PSF directory at least, I think).
  • sgcad
    Thanks. Do I understand your reply correctly that the mapped names are already present in the PSF directory? If yes just to ask the obvious: Is there a setting that would prevent writing the mapped names?
