  3. Issue with documentation browser, Cadence Help
  • Subscribers 136
  • Views 4576
spatz
spatz over 2 years ago
IC6.1.8-64b.500.27
PVS 21.12-64b
The documentation browser Cadence Help cannot open PVS documentation.
When hitting F1 in PVS DRC Result Viewer the following error message is shown:
Unable to show help document. Help file not found. Check PVS installation.
When hitting F1 in PVS LVS Run Submission Form I get the following error message:
ERROR(HELPAPI-404): [...]
tagfile PVS.tgf missing from the directory /../PVS_21.12.000/doc/PVS
I checked this directory. It does exist and also does the PVS.tgf file. This file is non-empty.
I tried adding the /PVS_21.12.000/doc manually to Cadence Help via Settings > Library > Add Library.
It does not work.
