  3. How to get coordinate of all pins from layout view?
  • Subscribers 136
  • Views 4823
ichiro
ichiro over 2 years ago
Hi all
I'd like to confirm the coordinate of all pins if those are correct.
How can I get it?
Ichito
  • RobMan
    RobMan over 2 years ago
    Top level pins or instance pins?
    Bear in mind the pin objects will be shapes. So unless you manipulate the data you will not get a single coordinate.
    How will you deem "correct"? What are you checking against?
