  3. can I have an if statement in assembler variables
  • Views 5935
Mooh
Mooh over 2 years ago
Hello everyone,
I'm trying to create a variable that takes on different values based on the value of another variable. I've attached a screenshot to illustrate what I'm trying to achieve. Can anyone help me with the syntax or approach to implement this in Cadence?"
  • JankoK
    JankoK over 2 years ago +1
    Hi Mooh, This is probably what you are looking for: Syntax to use conditional expressions in ADE design variables I think designers are mostly using ternary operator for conditional expressions, because…
  • JankoK
    Hi Mooh,
    I think designers are mostly using ternary operator for conditional expressions, because it used to behave the best. Nowadays, all of those should work just fine.
    I see you are swapping different S-parameter files, you could do this from Corner Setup too, or by using config view.
    BR
    /Janko
  • Mooh
    Mooh over 2 years ago in reply to JankoK
    Hi Janko,
    I wanted to express my gratitude for your help. The solution you provided is exactly what I was looking for. I have attempted to implement it and am pleased to report that it works perfectly.
    Best regards,
    Mooh
