  3. VSR in P2T mode: How to avoid router from shorting two different...
  • Subscribers 136
  • Views 4651
VSR in P2T mode: How to avoid router from shorting two different pins together
MARTH0401
MARTH0401 over 2 years ago
I am using the P2T mode style device level routing in version IC23.1
For some reason, the router does not recognize two diffrent pins and ends up shorting them. Are there any settings I can apply in the environment (CIW) or VSR wire assistant to avoid the router from shorting two different pins?
Thanks!
  • RobMan
    RobMan over 2 years ago
    The router should nor create a short. I recommend contacting customer support.
