  3. use of variables in bsource expression
  • Subscribers 136
  • Views 5997
RM202408071340
RM202408071340 over 2 years ago
Hi - I would like to use a bsource to model a nonlinear element and pass a CDF variable to the expression that defines the behaviour of the bsource.
For example, in the following expression, I would like to use the Rm_ref and Vbias_ref values defined in the CDF: I(iprb)*pPar("Rm_ref")*pow(pPar("Vbias_ref"),2)/pow(V(VBIAS),2) but I get the following error:
ERROR (SFE-1997): "input.scs" 106: Cannot run the simulation, because I10.I6 in parameter `bs_par_0': Unknown parameter `Rm_ref' has been specified in expression `pPar(Rm_ref)' Correct the expression and rerun the simulation.
ERROR (SFE-1997): "input.scs" 106: Cannot run the simulation, because I10.I6 in parameter `bs_par_1': Function `pPar' is not defined. Update the netlist to define the function.
Thanks for your help.
    This is complicated by the fact that the expression on the analogLib source intentionally has ParseAsCEL and ParseAsNumber set to "no" or is marked as "Literal" if you look at it in IC23.1 (in the CDF). This is because the expression would be misinterpreted if interpreted as AEL (aka CEL) - it's a native expression in the simulator.
    You can refer to parameters using just the bare name (e.g. Vbias_ref) without the pPar().  The trick is that you want them to appear in the subckt when netlisted - so they need to be used as pPar() in another field. You can achieve that by setting:
    Expression: I(iprb)*Rm_ref*pow(Vbias_ref,2)/pow(V(VBIAS),2)
    Temp rise from ambient: pPar("Rm_ref")*0+pPar("Vbias_ref")*0
    (in other words, the result will be zero for the temp rise, but they will reference the pPar so that it gets netlisted in the subckt). As a result, the netlist would be:
    // Library name: mylib
    // Cell name: forumbsource
    // View name: schematic
    subckt forumbsource a b
    parameters Rm_ref Vbias_ref
      I0 (a b) bsource v=I(iprb)*Rm_ref*pow(Vbias_ref,2)/pow(V(VBIAS),2) \
        trise=Rm_ref*0+Vbias_ref*0
    ends forumbsource
    // End of subcircuit definition.
    // Cell name: forumbsourcetb
    I0 (a b) forumbsource Rm_ref=2 Vbias_ref=3
    A made-up example (I don't have the iprb present or VBIAS node), but hopefully you get the picture.
