  3. Changing Netlisting Procedure for Spectre Include Compo...
  • Subscribers 136
  • Views 6270
Changing Netlisting Procedure for Spectre Include Component
sgcad
sgcad over 2 years ago
Hi
In How to create a component which netlists as a spectre include statement, a cell is described that allows to include a Spectre netlist through a schematic view. This is achieved with a netlisting procedure (abNetlistIncludeStatement).
How can I change the include cell such that it uses another netlisting procedure instead of abNetlistIncludeStatement? As far as I understand, this should be done through the CDF editor, but I struggle to get this right. If I open the CDF editor and load the include cell, I'd have expected to find abNetlistIncludeStatement as 'netlistProcedure'. Instead, all fields are just empty. If I explicitly load the 'data.dm' file from the include cell, I get the warning
*WARNING* 1 unprintable character passed as a field string value was changed to a space
*Error* strlen: argument #1 should be a string (type template = "t") - nil
and 'gE#' is shown as 'netlistProcedure'.
What am I doing wrong?
Thanks very much for your help.
    I don't know where you're looking - I just downloaded the 616lib.tar.gz attachment (I wrote the article many years ago) - and then looked in the CDF:
    As you can see, the netlistProcedure is clearly filled in (you need to look at the spectre simulation information).
    It makes no sense to do load("data.dm") as this is a binary database representing the "property bag" and is not a SKILL file to be loaded - hence the unusual error you get.
  • sgcad
    sgcad over 2 years ago in reply to Andrew Beckett
    Thanks very much for checking on your side.
    I've recently copied the include cell to a different library, and apparently something must have gone wrong here. I've now copied the cell again, and after that the CDF data showed up as expected...
