  3. An instance parameter cannot be a variable when using the...
  • Subscribers 136
  • Views 6343
An instance parameter cannot be a variable when using the SFE parser
MikeA
MikeA over 2 years ago
I am adding some Spectre primitives to my Verilog-A model and just found these can't contain variables as values, just checking whether there is a way to overcome this limitation and, in case, for an explanation of the root cause.
My module has something like:
module my_module(a,b)
real mynumber = 3;
cap #(.c(mynumber)) c_test  (a,b);
And parsing gives the error in the title. There's no such error if I define `mynumber` as a parameter, but then I have it appearing in the properties dialog and this is something I don't necessarily want to have since the number of these variable parts might start to grow.
Thanks for any hints you might like to give Slight smile
Michele
    Andrew Beckett over 2 years ago +1
    No, this is not supported. If you had: parameter real mynumber=3; then it would be OK - and you can override mynumber on the instance of my_module too - because then it's constant. This is documented…
    then it would be OK - and you can override mynumber on the instance of my_module too - because then it's constant. This is documented in the Verilog-A documentation:
    Overriding Parameter Values from the Module Instance Statement
    Using the module instance statement, you can assign values to parameters by explicitly
    referring to parameter names. The new values must be constant expressions. The format for
    overriding a parameter value on an instance statement is as follows:
    moduleName # (.parameterName(constantExpression)) instanceName (ports) ;
    For example:
    vdoubler # (.parm3(4.0)) vd1 (qin, aa1) ;
    The challenge if it was a variable is that the component value would change over time and this is something you can't do in spectre either (other than via dynamic parameters in transient, which allows changing at discrete times rather than in the solver loop). Changing over time could lead to topology changes and would also be difficult for the convergence algorithms too.
  • MikeA
    MikeA over 2 years ago in reply to Andrew Beckett
    Thanks for the quick reply Andrew!
    I didn't think of the fact that other variables not defined as parameters could in principle change during simulation, now that you say that, it's pretty clear!
    BTW, can you point me to the exact name of the documentation for Verilog-A in the Virtuoso Help? Or any other place in the support portal?
    I see the AMS manual and I know Verilog-A is a subset of -AMS but I can't see a verilog-A language reference manual in the docs.
    (There is some sort of appendix in the "other simulation topics" of the Spectre Reference, but not a "complete" manual)
    Michele
    Andrew Beckett over 2 years ago in reply to MikeA
    Hi Michele,
    The manual is in the Spectre installation (so you can access with "cda" or "cdnshelp" run from the SPECTRE stream, or by pointing to the documentation library there). It's called <SPECTREinstDir>/doc/veriaref/veriaref.pdf and is also here: Cadence Verilog-A Language Reference
