  3. Related to "How to specify phase noise as an instance parameter...
  • Subscribers 136
  • Views 3394
Related to "How to specify phase noise as an instance parameter in spectre sources (e.g. vsource, isource, port)"
mzn ehv
mzn ehv over 2 years ago
I am trying to specify the phase noise as an instance parameter of spectre sources such as port and vsource as mentioned in the article  https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000tiraEAA&pageName=ArticleContent
When I create a test bench containing one port without specification of phase noise and other port with specification of phase noise, I do not see any difference in their time domain waveforms. So, it looks like it’s not incorporating the phase noise as required.
I am using cadence-icadvm-/20.10.340 and spectre 23.10.538.isr10. Attached is the netlist of the testbench.
// Generated for: spectre
// Design library name: AAA_AA
// Design cell name: pn_modelling_tb
simulator lang=spectre
global 0
parameters fin=20M tstop=1000/fin
// Cell name: pn_modelling_tb
// View name: schematic
R0 (clk 0) resistor r=50
R14 (ideal_clk 0) resistor r=50
PORT1 (clk 0) port r=50 type=sine freq=fin ampl=1 isnoisy=yes \
noisetype=ssbphasenoise noisevec=[ 1K -100 10K -100 100K -100 1M \
-100 10M -100 ]
PORT0 (ideal_clk 0) port r=50 type=sine freq=fin ampl=1
iabstol=1e-12 temp=27 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 \
sensfile="../psf/sens.output" checklimitdest=psf
tran tran stop=tstop write="spectre.ic" writefinal="spectre.fc" \
annotate=status maxiters=5
save ideal_clk clk
Is there anything which I am missing here?
    You're not running transient noise (or a pnoise/hbnoise analysis), so you won't see any noise generated by this source.
    With noisefmax=fin*10 (say) on the transient analysis, the noise is generated - although you're unlikely to see it as it's small - in reality you'd have to do an DFT of the results, in which case you'd want to set strobeperiod and ensure that the DFT sampling interval coincides with the strobeperiod.
    Of course, if you do this, you'll also get the thermal noise from the resistor and the 50 ohms in the port - and any other devices in the real circuit. Note that the isnoisy=yes on the port is redundant because noise is enabled on sources by default, just doesn't appear in a non-noise-related analysis.
  • mzn ehv
    mzn ehv over 2 years ago in reply to Andrew Beckett
    Thank you Andrew for your response.
    When I enable transient noise, I indeed see the difference between noisy and non noisy source.
    To remove the impact of 50 ohms in the port, I changed the source to vsource keeping all other parameters same. With -100 dBc/Hz phase noise floor and fin = 20 MHz, I expect an rms jitter of 355 ps, but evaluation using calculator function 'rms_jitter' (integrated from 1 to 10M) yields number in the ballpark of 250 ps (with noisefmax swept from fin*5 to fin*20 and 1k-10k fin cycles). Why these two numbers are differing?
  • mzn ehv
    I am trying to specify the phase noise as an instance parameter of spectre component vsource. I can verify the applied phase noise profile in pss-pnoise is correct but when I enable transient noise, I do not see expected integrated rms jitter. With -100 dBc/Hz phase noise floor and fin = 20 MHz, I expect integrated rms jitter of 355 ps, but evaluation using calculator function 'rms_jitter' (integrated from 1 to 10M) yields 246 ps. Why are these two numbers differing? I am using cadence-icadvm-/20.10.340 and spectre 23.10.538.isr10. Attached is the netlist of the testbench.
    // Point Netlist Generated on: Aug 14 17:12:45 2024
    // Design Netlist Generated on: Aug 14 17:12:44 2024
    global 0
    parameters fin=20M k=10k noisefmax=fin*100 tstop=k/fin
    // Library name: AAA_AA
    V1 (clk 0) vsource type=sine val0=-500m val1=500.0m period=1/fin rise=100f \
            fall=100f width=0.5*(1/fin) freq=fin ampl=1 sinedc=0 \
            -100 10M -100 20M -100 ]
    V0 (ideal_clk 0) vsource type=sine freq=fin ampl=1 sinedc=0
    tran tran stop=tstop noisefmax=noisefmax noiseseed=1 write="spectre.ic" \
        writefinal="spectre.fc" annotate=status maxiters=5
    save ideal_clk clk
    Thank you!
    Andrew Beckett over 2 years ago in reply to mzn ehv
    Please don't ask the same question more than once (see Guidelines for the Custom IC Design Forum) otherwise this confuses where the answer should be given (if at all).
    Also, if this is urgent, you should contact customer support (submit a support case after logging in). I'd been hoping to reply but haven't had a chance to investigate due to the day job getting in the way (answering here is not part of my role at Cadence - we do so in our spare time, which has been lacking this week!)
