  3. an error when trying to create verilog cellview in virt...
  • Subscribers 136
  • Views 5613
an error when trying to create verilog cellview in virtuoso
ZG202408127156
ZG202408127156 over 2 years ago
Hi, Dear friends in Cadence community,
I'm trying to create a verilog cellview in virtuoso, but when I click to build a database of instances, this error appeared:
I solved the error above by adding the bin path of XCELIUM into my shell environment settings, but another error occurred:
anyone else have met the same problem? could you please share your experience with me? thank you so much!
Best Regard,
Zheng
    Zheng,
    Which XCELIUM version are you using, and which IC sub-version are you using? (Help->About will tell you the full version number for Virtuoso).
  • ZG202408127156
    ZG202408127156 over 2 years ago in reply to Andrew Beckett
    Hi, Andrew,
    Thank you for reply, my XCELIUM version is 22.09.005; and the virtuoso version is: IC618.260
    Zheng
