  3. Re-evaluate button
  • Subscribers 136
  • Views 4691
Re-evaluate button
RomanK
RomanK over 2 years ago
Does the 'Re-evaluate' button only exist in Assembler, and not in Explorer? I'm trying to confirm if this feature is exclusive to Assembler or if it can be found in Explorer as well
    If you have any sweeps or corners enabled in Explorer then you'll get a Results tab, and this does have the re-evaluate button. If it's only a single run (and none of the extra things such as checks and asserts which trigger the results tab) then you don't get a re-evaluate button, and the results are shown in-place (like ADE L did). In this case you can use the "Plot Outputs" icon on the right-hand side of the window to re-evaluate all the outputs.
