  3. Launching skill code from outside CIW
  • Subscribers 137
  • Views 6104
supriyo1985
supriyo1985 over 2 years ago
Is it possible to launch a skill code from outside the CIW window?
The CIW window is open, and I have a Python script running outside. I want to launch the skill code from the Python code, and it should be executed as if it were running from inside the CIW window.
I currently
load "*.il" in CIW,
but I want this done using the Python script.
By the way, I have to keep the CIW window and the layout editor open all the time as the skill code runs automatic placement and routing, which requires an active editor window.
It seems dbAccess -load "*.il" won't work in this situation.
Regards
Supriyo
  • henker
    henker over 2 years ago
    You might have a look at https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od00000066MSPEA2&pageName=ArticleContent
    Other options would be to create skill files in python and have virtuoso load them within a repeating timer function using hiRegTimer, although this polling may not be very efficient. and might also require protection against race condition. For the timer, see https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nZocEAE&pageName=ArticleContent
    However both would requite to first set virtuoso into a state that is can receive commands, than change to another window and run whatever script.
    In this case it might be easier to just have Virtuoso run the python code with the ipc functions and process the output, as it would  allow e.g. direct interaction from the layout editor.window. For mor information on this, see support.cadence.com/.../ArticleAttachmentPortal
  • supriyo1985
    supriyo1985 over 2 years ago in reply to henker
    Thanks. I will try.
