  3. How to disable 1/f noise in Xcelium AMS simulation
  • Subscribers 136
  • Views 1026
SpiceMonkey
SpiceMonkey over 2 years ago
thermal/flicker... noise can be enabled separately in Spectre simulator, while I cannot find the same option in Xcelium-AMS. Is it possible to disable 1/f noise in AMS transient noise simulation? Thanks
    This has not been added to the Simulation→Options→Analog form for AMS (for some reason), and so far I've not seen any request to add it (a couple of people have been given the workaround). I suggest you contact customer support and request an enhancement to add this.
    The workaround is to use the Miscellaneous tab of Simulation→Options→Analog and then in the "Additional arguments" field, enter something like:
    noiseon_type=[thermal]
    You can use noiseoff_type too, and the allowed values inside the square brackets are given in "spectre -h options" (or can be seen on the Spectre UI). Note that you would need to select the appropriate instances via the noiseon/off options on the Main tab, as you do with spectre.
