  3. Load previous simulation results into ADE explorer
  • Subscribers 138
  • Views 5588
unSkilled
unSkilled over 2 years ago
IC23.1-64b.ISR8.40
I have a lengthy simulation(~week) results folder.
I would like to load these results into an newly created ADE explorer view, where I loaded a state from an old, no longer supported ADE L view. Is there a way to do so?
I know I can use the results browser and use the calculator or use an ocean script, but I'm looking especifically for a solution in which I leverage my old saved state and ADE Explorer. I don't want to load the state and re-run the sim as it would cost me a week. In ADE Assembler it is possible to use "load setup to active" from the history, but AFAIK this only works for simulations that were run in that maestro view.
  • JankoK
    JankoK over 2 years ago
    Hi unSkilled,
    I think that this is doable, but you will need to contact your local AE or file an official case on Cadence support website.
    BR
    /Janko
