  3. prerun, reading temperature value(s) set in Maestro
  • Subscribers 136
  • Views 1348
Aldo3
Aldo3 over 2 years ago
In prerun script it is possible to read the current value of the temperature through temp().
Is it possible to read the value set in maestro, if it is a single value (e.g. 27) or a set of values (e.g. 0,27,50)?
Thank you
Best regards
Aldo
    Aldo,
    Assuming you're talking about the pre-run script via the right-mouse menu over the test name (rather than a pre-run script in a Run Plan), then I don't think this is possible. The run plan is run for each individual simulation in a sweep, so only sees the current sweep value.
    Why do you need this?
  • Aldo3
    Aldo3 over 2 years ago in reply to Andrew Beckett
    I'm simulating different calibration approaches: single-temp calibration vs. multiple-temp calibrations
    Thank you for the fast answer
