  3. Changing Default Path in Model Library Setup
  • Subscribers 136
  • Views 10460
sgcad
sgcad over 2 years ago
Hi
The PDK we're currently working with creates absolute paths in the model library setup. So the path to the simulation models looks like this:
/process/MyFab/MyTech_2024-05-12a/Models/Spectre/MySpectreModels.lib.scs
The problem with this is that if we switch to a newer PDK version, existing Spectre presets still point to the old PDK. This is tedious as the Spectre presets have to be manually updated, and it is risky if a preset is accidentally not updated and the models of the old PDK still used.
Instead, we would prefer paths in the model library setup as follows:
$MY_TECH/Models/Spectre/MySpectreModels.lib.scs
Where $MY_TECH is an environment variable that points to /process/MyFab/MyTech_2024-05-12a and can be easily updated. This environment variable is already used to define the technology library in the cds.lib file, but the model library setup still creates absolute paths.
How can this be changed? Currently we're still using Virtuoso IC6.1.8., but as we might switch to the most recent version in a couple of month, it would be good to have a solution that works in both versions.
Thanks very much for your help!
    Well, changing it for existing views is easy enough to do interactively - you can use the Model Library setup on one test and there's a button on there to update other tests (in the same maestro view) - as shown here: How to update all model libraries of all Tests at one time in Assembler
    For new views, it's a matter of locating where the default is being set (probably with an envSetVal using modelFiles, or sometimes using asiEnvSetOptionVal for modelFiles too). Sometimes this is in the libInit.il of the technology library in the PDK, but it really depends on the PDK. Then you can change to using the env var (I agree, using the env var is much safer for PDK migration).
    This might help too: How to update models defined in a maestro view
  • sgcad
    sgcad over 2 years ago in reply to Andrew Beckett
    Thanks very much for your response. I was able to locate the SKILL code that sets the path. libInit.il calls a separate function, which then uses asiEnvSetOptionVal as follows:
    scsModelList =
        list(
                        list(strcat(libPath "/../Models/Spectre/MySpectreModels.lib.scs") "tt")
                        list(strcat(libPath "/../Models/Spectre/MySpectreModelsRF.lib.scs") "tt")
        ); list
    asiSetEnvOptionVal(asiGetTool('spectre) "modelFiles"
                 scsModelList
    I'd prefer to not modify the PDK files, if possible. Can I just use asiSetEnvOptionVal in our .cdsinit to overwrite the path (after the technology library has been loaded and thus the libInit.il executed)?
    Andrew Beckett over 2 years ago in reply to sgcad
    Yes, you can do it in the .cdsinit - if you use ddGetObj("theLibName") first it would force the loading of that library's libInit.il and then you can override the setting afterwards as you suggested.
  • sgcad
    Thumbsup Thanks, seems to work fine.
