  3. Plotting template kept plotting placeholder history instead...
  • Subscribers 136
  • Views 4708
Plotting template kept plotting placeholder history instead of current history
HongJian
HongJian over 2 years ago
The plotting template kept plotting the old history result instead of plotting the latest run.
    I'm not aware of this issue happening elsewhere. What should happen is that if the plotting template has references to histories other than the "Placeholder History" - i.e. the history for which it was created, then these are kept, and any references to the Placeholder History should be replaced with the active history. If that's not what is happening, and you're using a current version, please contact customer support (submit a support case after logging in).
  • HongJian
    HongJian over 2 years ago in reply to Andrew Beckett
    Hi, thanks a lot. Will do that
