  3. Find the calibrated code in DC before moving to next Te...
  • Subscribers 136
  • Views 3933
Find the calibrated code in DC before moving to next Test
HongJian
HongJian over 2 years ago
Hi, I am trying to find the calibrated code in DC sim instead of tran simulation as it will be faster.
But is there any method that try sweep the code in the first batch and reiterate based on current run result and stop until certain tolerance is hit.
Only then, it will pass the result to the next test. Is this applicable to local optimization feature?
