  3. Regarding issue while using Auto Via
  • Subscribers 136
  • Views 4508
skillEater
skillEater over 2 years ago
I am getting the following Warning while using the Auto via from M1 to M2 and not able to add via.
*WARNING* incompatible scale from input layers.
Any help would be appreciated.
Thank you
Ganesh Doddipatla.
    I found some reports of this, and the issue seems to be resolved in IC23.1 ISR2, so I assume you're using something older? (this is why the forum guidelines ask for you to state the version used).
  • skillEater
    skillEater over 2 years ago in reply to Andrew Beckett
    Hi Andrew,Thank you for the reply.
    I am using ICADVM20.1 -64b.Is there any way to fix in this version or Do I need to update the version??
    Thank you
    Ganesh Doddipatla.
