  3. Regarding Code to Generate Analog Matching Set Pattern
  • Subscribers 136
  • Views 5125
NG202409204827
NG202409204827 over 2 years ago
Hi Team,
Apart from modgen is there any tool to generate various Matching set with variation percentage for the selected number of devices.
Thankyou,
Nagaraj
    Nagaraj,
    I don't know what you mean by "Matching set with variation percentage" and I also don't really see how modgens would give you this either? Please explain in more detail what you want.
  • NG202409204827
    I am looking for automatic matched device pattern placement with gradient mismatch percentage. Is there any skill code for this to generate different matching array for the given schematic.
    Nagaraj
    Andrew Beckett over 2 years ago in reply to NG202409204827
    I still don't know what you mean by "gradient mismatch percentage". If you want to generate different matching arrays from a schematic, that's what modgens are for - why would you not use modgens?
