  3. Not able to start XRUN (Error: No such file or directory...
  • Subscribers 136
  • Views 7826
Not able to start XRUN (Error: No such file or directory)
MT202407295352
MT202407295352 over 2 years ago
I have the problem that I cannot start XRUN. I am doing the following steps to start the tool:
source cadence_license_server
source XCELIUM_23.03.007_RHELx86.sh
xrun
After these steps I get the following error:
bash: /eda/cadence/2023-24/RHELx86/XCELIUM_23.03.007/tools/bin/xrun: No such file or directory
I have checked all the required dependencies for the Cadence tools, but XRUN still does not work.
This is the output from running checkSysConf XCELIUM2303:
[Copyright 2002-2022] Cadence Design Systems, Inc. All rights reserved.
This  program and online  documentation  may not be copied, modified,
re-published, uploaded,  executed, or  distributed in any way, in any
medium, whether in whole or in part, without prior written permission
from Cadence Design Systems, Inc.
============== checkSysConf:  Version 3.50 ====================
Date information gathered: Thu Sep 26 09:28:05 CEST 2024
Host Name ..............:  ___
Hostid .................:  ___
Operating System .......:  Linux / x86_64
OS Version .............:  Red Hat Enterprise Linux release 8.10 (Ootpa)
Kernel Version .........:  4.18.0-553.22.1.el8_10.x86_64
Hardware Type ..........:  x86_64
Memory .................:  63795 Megabyte
CPU model ..............:  Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
No. of CPUs ............:  12
Total Swap Space........:  6140 Megabyte
X Server ...............:
Patch Data file ........:  /eda/cadence/2023-24/RHELx86/XCELIUM_23.03.007/share/patchData/Linux/x86_64/redhat/8.0WS/XCELIUM2303
****************   Now verifying configuration     ****************
Validating Kernel requirements...
            Minimum             Installed                   Status    Info
            4.18.0-147          4.18.0-553.22.1.el8_10.x86_64PASS
Validating MEMORY requirements MegaByte ...
            4096MB    63795MB   PASS
Validating SWAP requirements in MegaByte ...
            0MB       6140MB    ----    None specified
Validating OS version requirement...
            8.1         8.10        PASS
Validating DISPLAY requirements...
          --- planes        --- planes                  ---     None specified
Validating PACKAGE requirements.....17 to check
#   PACKAGE                Release    Build          Installed               Arch        Status  Info
1   glibc                  2.28       72             2.28-251.el8_10.5       x86_64      PASS
->  'GlibC'
2   elfutils-libelf        0.176      5              0.190-2.el8             x86_64      PASS
->  'Libelf Library'
3   ksh                    20120801   26             20120801-254.el8        x86_64      PASS
->  'ksh'
4   redhat-lsb-core        4.1        47             4.1-47.el8              x86_64      PASS
->  'lsb'
5   mesa-libGL             19.1.4     3              23.1.4-3.el8_10         x86_64      PASS
->  'Mesa libGL'
6   mesa-libGLU            9.0.0      15             9.0.0-15.el8            x86_64      PASS
->  'Mesa libGLU'
7   motif                  2.3.4      16             2.3.4-20.el8            x86_64      PASS
->  'Motif 2.3.4'
8   libXp                  1.0.3      3              1.0.3-3.el8             x86_64      PASS
->  'libXp'
9   libpng                 1.6.34     5              1.6.34-5.el8            x86_64      PASS
->  'libpng 1.6'
10  libpng12               1.2.57     5              1.2.57-5.el8            x86_64      PASS
->  'libpng 1.2'
11  libjpeg-turbo          1.5.3      10             1.5.3-10.el8            x86_64      PASS
->  'libjpeg'
12  expat                  2.2.5      3              2.2.5-15.el8_10         x86_64      PASS
->  'expat XML parser'
13  glibc-devel            2.28       72             2.28-251.el8_10.5       x86_64      PASS
->  'GlibC-devel'
14  libnsl                 2.28       72             2.28-251.el8_10.5       x86_64      PASS
->  'libnsl'
15  readline               7.0        10             7.0-10.el8              x86_64      PASS
->  'readline'
16  ncurses-compat-libs    6.1        7.20180224     6.1-7.20180224.el8      x86_64      PASS
->  'ncurses'
17  compat-openssl10       1.0.2o     3              1.0.2o-4.el8_6          x86_64      PASS
->  'OpenSSL 1.0.2o'
Normal exit. This workstation (___) status is: PASS
Host ___ has a Cadence supported Linux configuration.
Exiting checkSysConf ... Good-bye
I know that a similar post exists (community.cadence.com/.../not-able-to-invoke-xrun), but all suggested solutions do not solve my problem.
Max
  • Alonso Schmidt
    Alonso Schmidt over 2 years ago
    Hi Max,
    The solution presented in the following article may solve this:
    Running xrun/xrun -64bit, SimVision, and Specman commands gives "Command not found" and "No such file or directory" errors on RHEL 8
    "To resolve this, you need to ensure that the Xcelium 64-bit binary path comes first in the search path. For example:
    %setenv PATH <xcelium_install_dir>/tools/bin/64bit:<xcelium_install_dir>/tools/bin:$PATH"
    Can you please try it and let me know if it helps?
    Alonso
  • MT202407295352
    MT202407295352 over 2 years ago in reply to Alonso Schmidt
    Hi Alonso,
    Thanks for the quick reply. The hint to run the 64 bit binary helps a lot. I am modifying the XCELIUM script as follows:
    export PATH="${PATH}:${CDS_XCELIUM}/bin/64bit:${CDS_XCELIUM}/tools/bin/64bit:${CDS_XCELIUM}/tools/cdsgcc/gcc/bin"
    and everything works fine.
    Max
